1 - 6 of 6 Posts
I will start by stating that I have already read the previous threads about the Cobra alarms on the Elise that are on this sight. I just bought a used 2005 Elise that came with two keys with remotes. One of the remotes works fine but the other on will not work. I put a new battery in the remote that would not work and went through all the procedures as listed in the manual, in this sight and on a video on the web. When I press both buttons on the remote it blink then stops after about 10 seconds. When I release the buttons the light stays on when I insert the key and turn on and off three times the dash lites goes on then off. So far so good. When I turn the key back on and it blink the proper amount of blinks(3) for the first number in the code and I turn it off and the back on it will not blink for the second code #. Any ideas on what to do?????
Vendor
Bill, The timing of that sequence can be tricky. Play with turning it of and on a bit faster and also a bit slower. Once you get it, it is pretty easy, but can be frustrating at first.
2005 Elise
It sounds like it is you timing with the pin number. Try watching a youtube video on it and it may help you to get the timing correct. It took me 4-5 tried my first time.
2005 Elise LSS Saffron Yellow
Yes, this is a pain. It took me three tries once I had the PIN from Lotus. I get to do it again because I disconnected the battery to swap to my test ECU and it reset the beeper loudness again...
For other issues, this may help.....
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
1 - 6 of 6 Posts
