2002 Esprit - Optima battery static charge 12.7
Out of the clear blue sky, alarm siren started bellowing regularly until I disconnected the battery. Read thru all the alarm siren related threads. Threads seemed to indicate that a bad battery could cause this problem. However, as best I can tell, the battery tests ok. Would a bad battery in the siren cause this to occur?
Where is the siren located in relation to the fuses, relays, OBD port under the right quarter panel?
Thanx.
Thanx.
