1 - 16 of 16 Posts
Might be worthy for the library
My OEM brake reservoir cap cracked about 4 months ago. I tried to get the cap from the dealer. But they don't sell just the cap by itself. They will only sell it as a set with the plastic reservoir for ~$170.00. Are you crazy, I'm not gonna pay that. :eek: I did some research on the thread size and finally found a replacement from ATE for ~$10.00. ATE doesn't list the part to use with Lotus. They are for some 80s BMW 5 series or something. Here is the part number incase some of you guys need to fine a replacement:
Brand: ATE
Part# 03.3556-1124.2 (390433)
Label Electric blue
ATE Cap
Product
ATE Cap
Plastic
ATE Cap installed
Vehicle Auto part Yellow Car Automotive wheel system
Cracked OEM cap
Yellow
Shuold also be the same cap MANY Porsches take.........YMMV
Somehow I'll bet that Porsche doesn't attach their reservoirs with a single tiewrap though (note above, and yes, it's like that from the factory).
Holy ****, a tie wrap???
What's the chassis bonded with.........bubblegum?
Every time I do a brake fluid change I grit my teeth. You can actually grab the reservoir and wiggle it around a bit without much effort.
Come to think of it, the chassis adhesive does look a bit like bubblegum!
-eek-
Props to mlk_f1 for finding the alternate cap - this stuff can be a pain to track down.
Where can I buy one of these? I cant find it anywhere?
Thanks
Just a quick bump to say thanks and this information is still useful in 2019! I was able to order from autohausAZ and can actually pick it up locally here in Phoenix.
big thx from the land down under. i am missing the rubber cap so went ahead and got this ATE replacement. Will take a while to ger here from the US but at least it will be fixed.
wish i had a rubber fitting that could cover it up in the meantime. ��
1 - 16 of 16 Posts
