Can you slightly feel it through the steering wheel? If so then its the steering rack. Hope you got warranty.
Can't feel anything from steering wheel.
Still have 3 weeks of warranty... will have to dig FAST!!
I am having the same clunking issue with my '08 Exige with about 10k miles. It feels like mechanical tapping through the steering wheel but seemingly only when the suspension is not loaded up (slow speeds, straight lines, minor road irregularities.)Going at the dealer on Friday
I'll post the results
Thanks for the comments though
pierre
What you are describing are the classic symptoms of a worn steering rack.I am having the same clunking issue with my '08 Exige with about 10k miles. It feels like mechanical tapping through the steering wheel but seemingly only when the suspension is not loaded up (slow speeds, straight lines, minor road irregularities.)
Recently, the tapping started to be accompanied by an audible "thunk." I'll share what I learn if you do. What did your dealer have to say...?
I wouldn't be so certain it is the rack. In your initial post you said the clunk is coming from the right hand side of the car. That is not normally where the worn rack clunks are heard. The clunking from a worn rack usually is heard from the area where the lower steering column attaches to the rack pinion on the left side of the car by the driver's feet. Read the post from NeedANewCure again. That is a very accurate description of worn rack symptoms and differs from what you are describing. Of course, pinpointing where a clunking sound is coming from on a car can be very subjective. Have you tried having a passenger listen with you for the clunks to give their opinion?I'm still struggling to find the problem. I went to the dealer just before my warranty expires and they told me it is my right shock... :no: Easy because I changed the suspension.
I just did your test and I do hear a little "thumb", very quiet, when I do it. I suspect you are damn right...
Now, back to the dealer... :evil: Even if my warranty is expired. I need to know.
Pierre
After all those tests it sounds like you have narrowed this down to your rack. With all your shock testing, it certainly can't be a bad shock. Have you tried taking someone with you to help listen for the source of the clunks, or maybe have them drive the car while you listen from the passenger side? I feel for you with this clunking, because I went through a similar process with my car and it turned out to be the rack.Tesprit,
I did that test with another shock. The clunk was still there. The harder the adjustable shock is, the easier it is to hear the sound when I hit a crack or a small bump on the road. I also triple checked the adjustable sway bar, nothing loose.
I will test it with my original Bilstein (base suspension...) Thursday.
After testing with 3 different shocks, I doubt something else than the rack can be the source of this noise...
Thanks for your help, really appreciated
Perre
