I helped race-technology implement the canbus stuff for the lotus, so one of the guys locally bought a setup from them, and i'm helping with the install.
I just got it up and running on the bench, it looks like a rats nest but thats all coming from the complete front side harness i have on the test bench, and i have the dash2, aim mxl and a motec all wired up (the motec isn't ready yet since i'm awaiting an adapter, hoping that one will be next)
Since its me doing it for the owner, its a complete plug and play setup, you pull off the cluster, disconnect the two plugs and plug in the dl1/dash2 and thats it.
Obviously if you need stuff the can bus or cluster doesn't support, you'll have to wire that in, otherwise you won't, you can input the various warning lights too.
And if you wanted to put the stock cluster back, unplug the dash2 and plug in the cluster, thats all there is too it (well taking the dash apart is another story)
Its a smaller unit that the Aim/Motec, but its quite clear and has a fair few options and its a lot cheaper setup.
( I get no kickback/money from race tech, just did it to help expand the options for people, i've helped with the pi research, aim , race tech and working on the motec )
