1 - 3 of 3 Posts
So when I bought the car it had a horrid rattle that was the usual cat heat shield falling apart.
As time went on a persistent rattle that seemed very obviously exhaust related, like you forgot to tighten a clamp but it resisted all my attempts to find it. Started chasing ghosts, replaced the serpentine belt idler pulley, rebuilt the supercharger, just in case...put a different exhaust.....
Put urethane motor mounts and it became nearly constant.
Finally I had it on the lift and I am looking around and there it is.
Support bracket for the exhaust manifold. One nut and silence!
It is a pretty crappy welding job, I assume a Toyota part, hopefully it is not really needed with a shorter exhaust system in this car. I have a spare manifold I picked up cause I wanted a spare cat, weld is the same[stupid robots]
Vertically centered horizontally just center right you can see the shiny bit where the bracket is broken and polishing itself
I just got the same rattle! Thank you. I will check mine.
Here's what my car looked like back in May 2019.
Luckily no rattle but now I'm ready for one.
1 - 3 of 3 Posts
