This thread originated in the psc forum.
This guy had bad radio reception and someone suggested to see if the radio was set to US or UK and to check in the manual and it's true!! there is a setting for US vs Europe.
My reply after checking the manual:
Good thing to know, here is what I found on the manual.
Radio mode
Setting the tuner
To ensure that the tuner works properly, the device must be configured for your region. You can choose between Europe and the USA. By default, the tuner is set to the region in which the device was sold. If you experience problems with radio reception, please check these settings.
- Press the MENU button 8.
- Press the softkey 4 assigned to the “SETP” display item.
- Press the softkey 4 assigned to the “AREA” display item.
- Press the softkey 4 assigned to the display item of the region that you require: “EURO” or “USA”.
- Press the joystick OK 7 or the MENU button 8 to close the
menu.
The settings are saved.
xclusivecar said:Check to make sure your radio is set for the USA and not the UK! My radio came set to the UK and I could not tune into much at all. After I set it to the USA, all channels magically appeared and are extremely clear! Your manual on the radio can show you how or I can look it up if youd like! Good luck.
Radio mode
Setting the tuner
menu.
