1 - 4 of 4 Posts
Short and sweet can someone please take off their front panel where the fuses are and take a pic of these connections. Not sure if the black clips go to what I have them plugged into or into the solenoid looking thing in the other pic . Thanks
Just turn the car on and rotate the thermostat from cold to hot. If the flapper moves from one side to the other then you've done it correctly.
there is not much you can mix up
flapper are the green yellow
those white body ones are the trinary
the thermostat is to the side of the outlet and has 2- 1/4 tabs
I must be missing some connections from when I did the blower motor can anyone take a pic of theirs no matter what I do I have 2 that don't connect to anything
1 - 4 of 4 Posts
