Hi.I have no issues with my S4s. Except needed paint work in a few spots but I'd call it a 20 footer.
Very few cars are 100%. A lot has to do with the fact that if you don't do your own work it can be very costly and time consuming to get that last 5% right. The door that doesn't close like it should, the rattle here, the squeak there, the burnt out bulb, the trunk that doesn't pop open easily, etc. Add to the fact that all of these are limited production, hand made cars and they all need an excessive amount of "fettling". Even from new! Then the car gets neglected and the service runs out of date. Eventually so many little things pile up and you don't know where to begin. Time to sell the low mileage car. It is low mileage because it doesn't run!Hi.
Is it due to your own hard work and passion?
Did you get lucky because of the previous owner was anal?
Curious.
It's been 3 years of persistence. I had the engine completely rebuilt a year ago. Not your topical build. Engine was brought down to the bare block and every piece jet washed and blueprinted. After that I worked on replacing anything and everything else I could find that was worn or started to look worn. If I see a leak I fix it. If the clutch got mushy I'd replace all the hydrolics just to be sure. If the brakes were mushy I'd replace all hydrolics. If a window was slow, I'd take apart the door. If the air conditioning felt warm, I'd replace the pump and dryer. Basically I haven't played around when it comes to maintaining the car. The previous owner was terrible about maintaining and so there was a lot to do. I just look at the car as a hobby and I don't get mad or frustrated with it because it is a hobby. Right now I'm painting engine parts. Not because it needs paint to run well but I'm doing it cuz I've fixed everything and now I'm bored.Hi.
Curious.
Hey Mikey,I do have ONE issue: My low fuel warning light comes on WAY too early. Like a half tank and its flickering like crazy. Especially around corners. Stupid thing
I could not agree more. They really are great cars. Sadly, just a lot of ****ty owners get a hold of them...nothing worse than when someone who can afford to buy it can't afford to own it...then blames the car...Actually I don't think the Esprit is as bad as people make it out to be.
The 4 banger is as good as any other car from the era, if it is cared for, and no worse than any other when it isn't. I've had way more issues with other older cars.
The major problem with the Esprit which earns it the reputation of an unreliable car is the lack of qualified mechanics, and the difficulty in obtaining parts, which then leads to poor maintenance and poor upkeep and substandard repairs often by well meaning owners.
Randy
