1 - 3 of 3 Posts
2005 UK import lotus exige.
I have just acquired a cup 240 sc kit. It was fitted to an 05 n/a exige like mine which is cable throttle.
I was told that there's a 5th injector that connects to the intake manifold which I assume I need a manifold from the cup 240?
I've got the whole kit including ecu but minus the intake manifold, intercooler ducting and the bosch sensor on the cooler as he reused them to go tvs1320.
Has anyone wired up the oem 5th injector?
I wan't to keep the install oem as possible and use what I have ideally without buying an engine loom from the cup 240 (if needed) or buying an aftermarket ecu and bigger injectors.
Thanks
You'll likely want to ask this question on SELOC since this is the US forum mainly and there are no DBC exiges in the us.
If you have a manifold that will accept the supercharger, I don't see why you can't weld in a 5th bung in a suitable/similar location as the SC240 manifold.
Kevin
1 - 3 of 3 Posts
