I just installed a set, with all the required stuff...ballasts, in-line resistors, new flasher relay. Connections all checked twice.
When I turn a blinker on, it blinks initially at a normal rate. But then after about 10 seconds, the rate steadily increases to fast, almost like an incandescent setup when a bulb is burned out. This change in blink frequency continues on, faster then slower at random intervals and rates. Same pattern on L/R. One thing I noticed, the flasher module that came with the LEDs had three pins vs four with the stock. Other than that I'm baffled.
