1 - 20 of 34 Posts
I keep meaning to call our club member who had our scales. I am curious about the stock weights with /without options.
Anyone weighed theirs yet?
i'll be corner weighting when my new shocks get here so i should have good data then (probably end of the month).
The registration on my car lists the weight as 2010 lbs. I wonder if this is a federal guideline they are using, since I thought that the regular weight was about 1975lbs.
Ps. In FL, the registration is based on the weight of the car, so I saved about $20 a year by getting rid of my old heavier 2700 lb car.
shay2nak
i used to live some miles away from a recycling plant and they had a scale there big enough for an entire 18 wheeler to get on and weigh itself. I was going to weigh my car here. But I'm not getting mine for another 5/6 months.
weight of elise
I weighed my car on a certified scale-1/4 tank of fuel,touring&lss=1920 lbs.this scale had a capacity of 120,000 lbs,so figure a margin of error of -+20 lbs. This was before I replaced the radio.:up:
I heard our weight was really closer to 1900. So with my QS exhaust I'm even less, I suppose. That's great.
Why would Lotus want to overstate the weight?? Is 1975 the weight in it's absolute heaviest form?
Discussion Starter · #12 ·
jml1952 said:
My little yellow one seems to weigh about 1 pound. :D
Gee Michael are you going to bring that one to the next WCLM :p
Thanks evryone, I thin I saw the 2xxxlbs somewhere and it was worrying me. I need to pester the guy with our club scales and weigh mine. I need to do something becasue it is STILL RAINING HERE. OK I have tken some more meds... feeling better....
My little one is stuck to a wood base with placque. Hard to get an accurate number. Hey Adamant... could you drag your bathroom scale into the driveway ? Weigh yourself holding the car, then just yourself.:p
Steve
gasoline density is among the lowest of liquids
wishiwerefaster said:
I've always heard 7 lbs./gal. as the rough estimate of normal fuel weight
I believe it's around 6lbs per gallon. I did some searching to confirm, and found various numbers. It seems to depend on the kind of fuel, but most of them were around 6lbs.
you're right. water is about 8.3 lb per gallon and gasoline runs from 5.8 to 6.5 pounds per gallon depending upon formulation
Once I install the Hawker PC680(13lb battery) I will go to our local recycling station and get weighed. They use their scale to charge residential customers for dumping their trash. Should be a little more accurate than the big rig scales..:p
Discussion Starter · #19 · (Edited)
Steve
LOL
You may laugh but that is how I measure wheels and stuff. I should get some kind of a scale that for 10-100lb range :D
Perry, where did you purchase the battery? I need to get one and fabricate a mount too.
1 - 20 of 34 Posts
