1 - 7 of 7 Posts
OK, I've searched, I'm sure I've seen this, but I have not been able to relocate. Questions: What are good operating temperatures for AO48s? I am interested in track temps for mortals. Also track temps for teeth gritting, almost in flames, rubber and brake dust spraying folks also.
how hard did you look?
-poke-
Advanced Search, Suspension (incl tires, etc.) key words "AO48" and "temperature". Any help making the search more specific or broad or what is needed will be appreciated. :confused:
Thanks Ace10. Nuthin' more fun than learnin'!
Seriously, I (obviously) have little idea how to really use the search function after more than a year onboard. Where might I read the details of properly using this search function? It is constantly pointed out that people should use it properly.
Anyway, thanks for the help. This helps me put my measurements from VIR last week into perspective. This was my first time using a pyrometer.
LF 26.5psi hot 192 187 187
RF 26psi 185 185 183
LR 29psi 198 194 196
RR 29psi 190 185 185
Comments?
depends on....
Tire temps will depend on the track lay out and your driving style. If you have mainly right hand turns that are long you will put more heat in the left front and so on. Tire preasure will also dictate heat. Make sure you cheack the heat over the whole tire. There has been talk of Co2 as the gass will lower tire temps but it is not worth getting the tangsand so on, same with nitrogen.
1 - 7 of 7 Posts
