1 - 9 of 9 Posts
Theres a pair on e bay I cant track down by model numbers cause they claim to be 3 years old and never used, want to be sure there authentic or that they would work on an 05 stock elise rim and tire. Do all rotors and brake lines from ap pretty much work for each other even with the three year old model. please tell me if this purchase is worth doing or not or how accessible the replacements parts are.
I don't think they will work unless you have LSS (won't fit under stock wheel).
If they are 3 years old then they will not be the same as the ones Lotus supply as a kit now, they will be the MS ones used along with a new Master Cylinder and rear calipers, running on 295mm disks.
also, they do not just bolt up, they were used on the S1's Ali front uprights that had been double drilled/tapped for both std and MS calipers.
Remeber, AP make a **** load of calipers, lot's look the same but as not.
so final question if i get these to my mechanic and purchase lines and rotors will they work on my 05 elise stock
We don't know, you are in uncharted territory :wave:
If I had to guess I would say no :shift:
AP caliper lisiting (and Pagids which go on them, 4 digit number)..a TON of AP out there:
AP Racing CP2195 D38 10.5mm 1362
CP2270 D46 17mm 1269
CP2279 D50 20mm 1270
CP2279 D50 17mm 1361
CP2279 D50 18mm on inquiry
CP2340 D43 16mm 1749
CP2340 D51 16mm 1265
CP2340 D51 20mm On inquiry
CP2372 D52 16mm 8040
CP2399 D43 15mm 1363
CP2749 D66 20mm 1218
CP2749 D66 25mm 1220
CP3215 D42 17mm 2126
CP3345 D44 16mm 2127
CP3558 D46 25mm 1813
CP3558 D51/53 25MM 1538
CP3714 D54 25mm 1268
CP3714 D54 20mm 1267
CP3894 D46 18mm 1852
CP3894 D51 18mm 1903
CP4296 D46 16.5mm 2141
CP5045 D61 24mm 1908
CP5119 D48 15mm 1587
CP5510 D43 16MM 1705
CP5510 D43 20MM 1283
CP5788 D48 20mm 1896
CP6070 D49 25mm 1674
CP6210 D54 20MM ON INQUIRY
CP6210 D54 29MM 2557
CP6210 D54 26.5mm 2688
CP6600 D55 16.7mm 20345
CP7031 D32 16mm (new F3) 8060
CP7040 D58 16.7mm 20346
CP7600 D46 16mm 20349
you need to know exactly what AP calipers these are, as in model number and piston sizes... (allong with mount spacing and bridge spacing)
1 - 9 of 9 Posts
