1 - 4 of 4 Posts
Hi All,
I'm on my first week of ownership with an '07 Exige and trying to sort out the modifications the prior owner employed. In doing so, I've found an 2-wire male connector (green/white and black) coming from the harness (at cylinder 1) that is unattached. Any ideas?
Thanks much,
Gene
Discussion Starter #2
After more digging it appears that the charcoal canister and eval loss system was removed. Thinking this might be the purge control solenoid connector?
I'm nearly certain it has to do with the canister / evap system. Mine has the connector hanging loose as well.
I couldn't find the wiring color codes in the manual though. According to it the wire should be Green/Pink or LightGreen/Pink.
Thank you! I peeled back the insulation a bit and the wires are black/orange and green/possibly pink, so I think that's correct.
1 - 4 of 4 Posts
