1 - 1 of 1 Posts
Saturday July 28th Autocross
James Woods HS in Winchester, VA is the location of the next Capital Driving Club autocross on Saturday July 28th.
Registration and tech inspection will be at 8:15 (giving you 15 extra minutes) and will promptly close at 8:45 to try to accommodate the full field, while still giving 6 runs. You must be DONE by 8:45. So if you arrive at 8:15 you won't have a problem. Don't arrive at the last minute.
The event fee for the Saturday autocross is $30 for members and $40 for non-members.
If you have problems, we can also print barcodes for you at the event.
On-line Reservation System
Member reservations (or participants that will join the club upon showing up) for any events can be made at any time. Open reservations for non-members for this event begin Friday July 20th.
New Members
We will be accepting new members at this event. If you plan to join the club at this event, you may make a reservation at this time by doing the following:
1. Use "0" as the member number (a permanent number will be assigned to you after you join and you will get a temporary number for this event)
2. TYPE "I will be joining the club at this event" in the NOTES section when making you reservation.
$10 Discount on Second Slot
To help increase interested in this event at James Wood HS in Winchester, VA, we are offering the following special.
For anyone paying for a second slot, the second slot will be $10 off. So if you are a member the second slot for a member will only be $20. If the second slot is for a non-member the cost will be $30 (rather than $40).
The second slot can also be used the same driver (e.g. they would drive in two heats) or for a guest.
If you sign up for a second slot, just type "Second Slot" in the Notes Section. Otherwise, we may think you mistakenly submitted duplicate reservations.
Remember, to make a second slot, MAKE A SECOND RESERVATION (if the second slot is for a different person, type "Second slot for (type the name of the first slot person)".
-Several people used the second slot for a guest (some that never autocrossed with CDC) -Many participants used the second slot to get 12 runs -Some used the second slot to be a point autocross in the 6 morning runs (since only the first 6 counted for points) then treated the afternoon as a TNT by trading cars with other two slot participants
This offer is only extended for this event at James Wood HS on Saturday July 28th, 2012 and will only be offered at James Wood HS.
If you have any questions, let me know at [email protected].
Ed
1 - 1 of 1 Posts
