1 - 20 of 29 Posts
Guys,
I'm told I need a new aux. belt and tensioner. It's a fair bit o'coin for a belt and tensioner so I'm wondering what that belt drives other than the AC. Has anyone simply removed it along with the tensioner? I think I have used my AC three times in two years so unless there are other considerations it seems like a reasonable idea to simply get rid of the tensioner if it is going to have habit of going bad. Opinions invited.
tia,
crash
Crash said:
I'm well out of the warranty. :D
ah. gotcha. i saw the two years of ownership and assumed less than 36K miles.
of you mechanically inclined? perhaps source the parts (at least the tensioner) directly from toyota? i must say that looking up there, it is a tight squeeze. this isn't an "engine out" sort of thing is it?
No, but you'd probably want a rack. I have access to a rack but the service guys I see are very helpful and easier than arranging some side work with a buddy of mine. I do hook up with my buddy for the simple but time consuming jobs though as the labor can really kill you at the dealer.
Here's the explanation of the belt and ancillaries from the manual.
A single multi-rib serpentine type belt is used to transmit drive from the crankshaft to the water pump, alternator and a.c. compressor, with a slave pulley fitted in place of the power steering pump used in other applications. A hydraulically damped, spring loaded tensioner arm applies tension to the back of the belt, and is maintenance free. The belt itself should be inspected for condition at each service interval, and if it exhibits any evidence of physical damage, cracking, fraying, perishing, abrasion or contamination, it should be replaced. In the case of oil or coolant contamination, the cause must be identified and rectified, and each of the pulleys must be thoroughly degreased before the new belt is fitted.
Jerry
Jerry
I really need to download the shop manual.
My "maintenance free" tensioner is making a real racket apparently. The quintessential squeaky wheel. I wonder how much of the job is labor and how hard it is to "diy" it. Or, I could turn up the radio. :p Has anyone else heard of the tensioner going south on them?
The auxiliary belt drives the auxilariary items. Duh.
xtn
Discussion Starter #10
That's helpful, thanks.
My experience with car engines is limited. It seemed logical to me that aux belts drove aux systems like an AC and primary systems were driven by another belt like the water pump and alternator. I just learned that the elise has only one belt so it drives everything. So again Etalk proves how valuable it is to non-mechanics and beginners looking for information. Thankfully, there are people that provide more input than xtn. -poke-
hasta
hasta
Wasn't intentionally being unhelpful. Just figured your question was already answered so it would be okay to make the dumb joke.
Could one install one on the side of the road like every other vehicle I have owned?
only if you were a wonder twin... the one who had the power to take the shape of liquid. i i swear, i can't even get my hand up there to feed the belt around the pulleys.
Don't know if this will help, but here are the diagrams of the belt from the Shop and Parts Manuals.
One page is WITHOUT the A/C compressor shown, the other shows the whole system. Parts List also attached.
Good Luck!
Regards,
Wayne
Discussion Starter #15
Oh hey no problem. I'm the first to admit I have tons to learn but I'm trying. I take a lot of flak for it for some reason. I know there are a lot of others like me. Etalk is a great place for us. It may have been a dumb question because I just didn't know. :eek:
Thanks for the post Waydui. I've printed it and it helps.
have a good one,
crash
so what did you end up doing? the tensioner is easy to take off.. I think its possible without taking off the wheel or undertray..
the easiest way is to..
-drive car on ramps
-pull undertray
-remove belt
-lift passenger side up
-remove passenger side wheel/liner
-2 10mm (I believe) and there's great access
-drive car on ramps
-pull undertray
-remove belt
Well, I had my tensioner replaced under warranty, and the mechanic (a good one) swore he never wanted to do another one. He had to loosen the motor mounts in order to get enough clearance to remove the tensioner. It's not so hard to reach the bolts, but there's not much clearance for removing the tensioner itself. By the way, the reason I had it replaced was that the water temp would increase a lower engine speeds. With a good tensioner, the water temp should stay at 186 - 188 F regardless of engine speed (in normal weather, at least). I didn't want to deal with a bum tensioner on my own when the car goes off warranty this Nov.
Jim
did he replace the cylinder only or the whole thing.. the cylinder is not hard to remove.. I've never pulled the whole assembly off.. cause anyone whose replaced the header has taken off the cylinder..
You can get the header off without removing it. I cut the air pipe, but better yet unscrew the header studs from the head: http://209.59.172.12/forums/showthread.php?t=28408
1 - 20 of 29 Posts
