1 - 20 of 41 Posts
I'm looking for an AGM battery to replace the third battery in three years for my 05 Elise. (yes, I know, I don't drive my Elise much so I finally bought a Deltran to maintain my next one)
Do any of these fit into the stock holding bracket? if so, which one would you recommend between them?
PC925MJT Odyssey PC925MJT Battery - Free Shipping: BatteryMart.com
PC1200MJT Odyssey PC1200MJT Battery: BatteryMart.com
9A35/85 9A35/85 AGM Battery: BatteryMart.com
MAR-9AGM47 9AGM47 Maintenance Free AGM Battery: BatteryMart.com
They're all so heavy I couldn't recommend any of them for an Elige.
There are decently light batteries that won't break the bank (Deka, Big Crank). Do a search on ETX-18L, ETX-20L and check the dimensions.
San
I have a Optima Yellow Top D35 for my Elise. Fits perfectly fine. I mean it weighs "a lot," but I didn't want to make or buy a custom bracket. Waste of time and money. Big whoop... 20 lbs more than the lightest battery offered for the Elise. Not a SIGNIFICANT weight difference.
By the way did you refer to this: http://www.lotustalk.com/forums/f321/battery-choices-information-64071/ because I'm assuming it doesn't fit in the stock holding bracket based on, "*requires custom bracket"
My battery 4.9 lbs w/540 cca with 36 Ah lithium ion so yeah it's very significant weight difference. Holds charge and cranks every time i go to use it which is every week or two. Makes up for all the extra cheese burgers i eat ;)
San
I have had an ETX-20L in my Exige for about 2.5 years now. It was inexpensive and has been as reliable as the two previous batteries. It was a direct replacement for a Braille 2015...same size, weight and zap.
The ETX-20L replaced a Braille 2015 (I replaced it at three years) that replaced the OEM battery (I replaced it at five years).
If you drive the car infrequently, it would be a good idea to plug the battery into a smart charger to extend its life by ensuring that it doesn't get drained to death.
My logic was that if plan to keep the car plugged in when parked (for more than 3+ days) then why not switch to a smaller battery and shave a lot of weight that is located in the worst possible place for weight distribution and handling (behind the rear axle)? The OEM battery is a pig and provides overkill capacity if you use a charger.
Super Moderator
Can you use plain ol' chargers on non-lead acid chemistries? I know LiPoly require special circuits.
The one I have just uses a regular charger (or did until the charger failed... then the battery went completely dead... and is now unrecoverable).
My fault... should drive more!!
LiFePO4 have a "close enough" charge voltage to good old Pb batteries that unless the charger tries to do something fancy, a normal charger works, albeit not optimally. To get a true 100% charge would require a balance charger with the correct current map/curve and access to each cell (I think the fancier LiFePO4 batteries like Shorai have these available), but the LiFePO4 batteries still provide plenty of cranking current (and last longer!) when charged below capacity by a lead-acid charger / the car's alternator.
In general a lead-acid tender is a bad idea for them as they degrade quickly if they're floated fully charged. I just use a cutoff switch when I'm not driving the car, I've had my LiFePO4 battery for 2 years now, and it still works fine, but for people who do extended storage a dedicated LiFePO4 charger is probably a good investment.
I love LIFE batteries. They actually hold their charge for a looooooong time and can be stored topped off without ill effects. I do a lot of RC flying and use LIFE packs in my transmitters instead of alkaline or lipo's. They hold a charge for so long and I don't have to worry about putting a storage charge on them and leaving them topped off damaging the battery. Only problem with them is that they will drop in voltage like a brick at a certain point much faster than other battery types and you need to watch out for that. I didn't even realize they had LIFE car batteries. Gotta look into that! I currently run a optima red top battery and it fits the stock battery tie down but its certainly not the lightest by a long shot.
I use this one. Alien Motion Lithium Battery - LiFePo4 Lightweight Power Sports Battery One year anniversary and no problems but treat it gently by using a cutoff switch. Also purchased their charger and give the battery a balance charge once every other month. Battery is extremely light and uses the battery hold down that came on the Odyssey PC925 that was in my Exige (with a supplied foam pad).
The OP specifically asked for an AGM. That's what I recommended. Deka and Big Crank are the same as Braille. All made by East Penn.
San
There are a couple different pairs of odyssey batteries and Lotus brackets from the various vendors, so I'd steer that way (I have the bracket that came with my BOE clam hinge and the appropriate Odyssey battery but I don't recall the model number).
For @DDJ74 and others like me who tend not to care about 20lbs, AGM batteries are cheap, lightER, and above all else allow you to ditch the factory mounting system which is an absolute abomination. That clamp is terrible and should not be allowed by any tech inspection for track or autox. Even if you have it tight, the trunk floor can flex and let the battery loose to terrorize your clamshell. There are enough threads on it (and I've had it happen, too) to establish my distaste of the stupid thing.
So that kind of insurance for the rear clam is hardly more expensive that the heavier options, even after the cost of the bracket. Definitely worth it and one of the greatest disappointments in lotus' engineering dept. Second to deciding to use their chosen suppliers for oil line clamps and radiators.
Plus you get marginally more storage space which is already at a premium.
Arch. Project Manager
I've used the Odyssey PC680 for around 2yrs now with no issues. If it sits for more than three or 4 days I'll either cut it off or put a battery tender on it.
reviving an old thread, any suggestions for a battery that will fit into the stock holding bracket? if so, which one would you recommend ?
Go to East Penn site, as San mentioned. You'll find direct replacement.
I have used an Optima Red Top over the last several years. Still going strong and starts up every time. It's been on a tender since last June but I do occasionally start the car up when I need to move it out of the garage every now and then, no issues and the battery health is still good. I did not have to order a special bracket as the stock one fit perfectly. It is a little heavier than the stock black battery by 9lbs but I'm no track rat and am fine with it.
I've used all kinds of batteries, but they all eventually die unless you can prevent them from being discharged. What has been more useful for me than trickle charging is a battery cutoff switch like the kind a few forum sponsors sell, or otherwise get one made for boats.
My current PC680 has lasted 3-4 years with a cutoff switch.
I don't know if it fits in the stock battery box, but the Shorai 36 works pretty well. I'm trying to keep it on the tender but I've left it 4 or 5 days without hesitation.
When it comes to the Amp hour figures on these lithium batteries, even the manufacturers told me to cut those numbers in half.
So on my 36aH equivelent, thats probably more like 18 real amp hours which is probably in line with your typical 4 cyl. Still may be slightly smaller in terms of reserve capacity, but this battery could most likely provide enough cranking amps to start a bus
1 - 20 of 41 Posts
