1 - 6 of 6 Posts
The passenger door pull came a bit loose today and I was able to just pull it off. It appears to have been put on a double sided black tape but seems due to the colder weather it has failed. I went ahead and pulled the drivers side one off as well as it had some slight play in it. This one was held on by a adhesive. What is recommended for the door pullers, has anyone replaced the adhesive and have something to reccomend? By door pullers I mean the black thing you put your hand in once you are seated to assist in closing the door.
Pls see last entry:
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
I was surprised when I bought two door pulls probably the most reasonably priced part on the car at $7 each and clear silicon is the way to go to adhere. I use GE others will work and the beauty of clear silicon is it flexes, it's removable and dries in 30 minutes.
Thanks for the help guys! I got 3m double sided tape on their right now and its seeming to hold fine. But I am going to use an adhesive when the weather is nice. I have a feeling the take will be fine for about a year than once the weather starts changing will eventually fail.
If you were replacing the door pulls on purpose....I'd say you hit the jackpot! When properly adhered, those things are a PITA to remove. Years ago I spent hours with a razor blade trying to get the stockers off to replace with some carbon fiber ones.
They are glued in with a semi removable material like BetaLink that requires a lot of elbow grease. If you are looking for a proper like stock adhesive to put the new ones on....you can go that route. 5 years later after using the medium mine are sticking fine.
1 - 6 of 6 Posts
