1 - 20 of 41 Posts
Like I know which model.......
Answer: 1 & 2
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Best for what? Looks? Speed? handling? Comfort?
He's on fire!
Another vote for the good ol driver mod
** The Enforcer **
Soon to be new owner looking at several all stock cars.
What is the best mod for these cars besides Ohlins?
OP is asking about an 05/06, so presuming an Elise/Exige, the best mod isn't Ohlins, it's Penskes. It's not even close between the two.
San
I like this too, but my first thoughts go to safety, as with mirrors, horns, headlights.
Best mod I ever did was the convex side mirrors. So much more driveable in traffic on or off track.
Reactions: jhentr
** The Enforcer **
That's interesting. I still have the stock mirrors, but I'll try to check out someone else's setup based on your opinion. Thanks.
San
San
Multivex is what they were called. Some occasionally come up but they are now rare, no longer made. There are threads I have not fully read, but seems like there are other solutions.
The best solution, but not Lotusy, is in our $22,000 Honda Civic Si. A tiny camera in the passenger mirror. Ought to be required on all cars. Touch of a button on turn signal stalk and a perfect view on center screen, with graduated marks to indicate safe passing. Endurance racers at nifht especially rely on them.
Any mid engine car is awful in traffic. Wide angle mirrors change this a lot. And not just the little stick on ones. I use the inside mirror to judge distance for point by.
Once we got to moving pretty well, a 6 point harness system was a great mod. No longer had to brace my knees into things through curves.
But this is only with a helmet and neck protector. A harness system on street is nuts. Just there for that racy look, but a real danger to your life.
** The Enforcer **
I bought my son a Civic Si after he totalled his normal Civic. I remember that feature, but he traded the Si in on a WRX STI. I had the original 2002 bugeye WRX, so I'm slightly jealous of "his" STI, even though I make the payments. I sure wish someone had bought me a nice car (or any car) when I was young.
San
San
San, this makes you much safer.
I have an extra set of Multivex mirrors and another from RLS.
You never have to turn your head.
g
San
I hear you. My Dad was an automobile dealer and I had all sorts of cars, but never the Lotus I wanted. “You wiill have to do that for yourself son.” Took me decades but evetually got three. So far.
I got my son a nice low mile Nissan 350Z. He modded it to an extreme. Not sure where he got that from?
So I wound up getting him a Mitsub Lancer to have something to actually drive.
I would really like to know your thought on that Lexus. Would you mind?
Thx.
g
** The Enforcer **
He can't have got the "stickers" from you. I won't even address the wing.
San
I deff was never one for stickers. That’s Gunpilot’s specialty.
But that wing is an APR, same brand most of we Lotus folk use. Real track car stuff. He has done a well thought out job with it. And after several attempts got an exhaust system that sounds less like a rolling explosion and more like a performance car.
1 - 20 of 41 Posts
