1 - 16 of 16 Posts
Direction's adjustable, the inner ring is a vent ball that moves around. You can't quite close it off though. I didn't weigh the factory vent - that's plastic so it has the weight advantage there, but it also has more parts and is overall bigger...probably a wash.
https://www.restomodair.com/shopproducts/quantum-vortex-billet-aluminum-a-c-vent/ this is the one I'm using in my car - 2.5'' inner hole & 2.75'' outer. 3'' works too, it's just a matter of aesthetics. The second pic I posted was a 3'' outer. I did have to dremel a little bit off the inner ring to get these to fit though. I suspect going back to stock may not yield great results if you do expand them, unless you shim.
So the 2.75” fits without dremel work? And what are the two options 1. Part only and 2. With system purchase?
Discussion Starter #10
They Sell AC systems and give you a discount if you buy their system - you don't want that. You want the "Part only" option.
Both the 2.75'' and 3'' require a bit of dremeling - the inner hose diameter is fine, it's just that these mount via universal compression fit, and our factory vents have four slits in the plastic - so you'll have to remove a bit to get these to fit. My carbon dash had smaller/less circular openings than the stock dash though, so you might be able to get away with a little less grinding. I feel like it'd be pretty easy to go back to stock with some shims, even if the hole became too big :)
Discussion Starter #11
Those look very nice. For my information, how do you remove the stock vents?
Thanks -
Mark
You could try pulling on them, but that's liable to rip the front vent piece from the hose piece off(ask me how I know). The best way to do it is to remove the dash trim piece(a few screws), and push it out from behind. They sit via a compression fit mechanism, similar to these ones(but not exactly the same, stock uses a four-slit compression whereas these alum vents use a universal fit).
I have a carbon dash too. But I’m just debating on forking out such serious cash for some vents. Thanks for all your info though.
Discussion Starter #13
Sure! Yeah I had second thoughts for sure, given the price but now that I have them I think they're worth it. They're really gorgeous in person, perfectly complement the carbon interior. They're also made in the USA, which I'm a sucker for.
Thanks for the information. I'll probably have the dash apart to install the garw LCD dash soon, so I can
do the vent replacement then. I've got a couple of the stock vents that are broken.
Mark
Hello looks awsome and great job, do you have some more pictures ?
Maybe one where you can see most of all vents in one shot? I like to know how it looks overall when all vents are mounted.
Are there any other vents on the market wich you can use ?
1 - 16 of 16 Posts
