1 - 7 of 7 Posts
Vendor
Blackwatch Racing Summer Sale!
Make sure you’ve got everything you need for a great summer of Autocross, Track Days, or just Cruising around in your Lotus!
Blowout pricing while supplies last on:
BWR 2 piece brake rotors! Regular Price $895 Blowout Price $745! Save $150!
The 2 piece rotors save over 1lb per corner! Look good and brake better!
Big-Bore Throttle Body for 2005 Lotus Elise and Celica GTS!
Regular Price $495. Blowout Price $395! Save $100 while supplies last!
This 70mm throttle Body is a custom casting for any throttle-cable equipped Lotus(2005) or Celica GTS! 15% more flow vs. stock. A must for modified cars.
Vendor
Discussion Starter · #2 · (Edited)
BWR Spec OS Giken Differential: This differential is the result of many tests with our cars and OS Giken. This differential features different ramp rates, pre-load, and center- ring springs to Maximize grip out of the corner while maintaining excellent corner entry characteristics! The best-performing Differential on the market today!
Regular Price $1890 Sale Price $1795! Save $95!
Vendor
Discussion Starter · #3 · (Edited)
Total Oil Control TOC Oil Pans – $545 + Free Shipping! While supplies last!
- Best featured Pan on the market to keep the oil around the pickup under extreme conditions!
- Relocated Temp sensor port for easy use.
- “scraper” plate captures oil slung from rotating assembly into the pan.
Vendor
Discussion Starter · #4 · (Edited)
Lots of other stuff on sale!
Other specials:
- Standard Studs: Regularly $92, on sale for $79! Choice of Silver or Black Lug nuts
- 2 or 3 Hole Gauge Bracket: Save over 10%!
- Rear License Plate Brackets: Regularly $85 On Sale for $75!
- CG Locks: Stay Planted in the seat: Save $5!
- De-Cat for Stock Header. If you want to remove your catalytic converter for track days or dyno work, this stainless steel De-Cat pipe includes and extra O2 sensor bung for a wide-band O2 sensor. Works with stock header and any exhaust. Off road Use only! Regularly $249 On Sale $219! Save $30 while supplies last!
Go checkout our website at:
blackwatchracing.com
I thought the weight savings was over 2 lbs per rotor, ~10 lbs total. How long will the sale last?
Thanks
Vendor
Discussion Starter · #7 ·
Folks, the Blackwatch Racing Summer Sale ends Saturday or while supplies last!
One last special: $100 off the next Rev310 Supercharger kit we sell!
1 - 7 of 7 Posts
