1 - 9 of 9 Posts
Anyone have some feedback on what the visibility will be like through the mirrors? Any noticeable blind spots due to frame, small back window etc?
My guess is that the car is so small I will probably be in the blind spot of others more often then not being able to see them.
Thoughts?
In my all too brief drive of a 111S, the b-pillar gives a blind spot. Taking the time to adjust the mirrors to compensate or shifting your head would help. Sure others with more seat time can fill us in.
Thoughts?
It's a little like driving a panel van, but with normal size rear view mirrors. The view from the inside rear view mirror was very limited in the Euro 111, I drove and it appears that the US seats (and 111R?) have much wider headrests. There is a tunnel view from either the inside rear view mirror or looking over your shoulder.
The outside rear view mirrors provide about the same view one would expect from any other car. Peripheral view from the driver's seat is pretty limited by the sail panels aggravated by the fact that you are sitting further towards the center of the car than normal due to the wide sills. You have to lean forward and to the left and look back to see to the left rear.
You just have to drive fast enough that you only need to worry about things in front of you. :D
Re: Re: Blind Spots??
Exactly. Christine from the Newport (actually Costa Mesa, but close enough) dealer said that Roger Becker told her, if in doubt (about seeing/being seen) "squirt" out of there, don't hesitate. If you hesitate, you're probably going to get into trouble. This car's greatest advantage will be its ability to accelerate away from potential problems, very quickly.
1 - 9 of 9 Posts
