1 - 5 of 5 Posts
I changed my oil for the first time this past weekend. Afterwards, the shifter would not go into reverse. I realized that I had clamped the cables with the under-engine tray. I used a yard stick to hold the control cables out of the way the second time I put the tray on and this worked out fine. Has anyone had this problem? Also, now my blinkers do not work. The lights on the dash are fine and I cannot hear the relay clicking. Any ideas?
could be the blue blinker relay under the dash in the center. my blinkers failed BUT it also wouldn't light up on the dash. replacing the blue relay fixed it. Also check if your hazard lights button is in the full off position and not stuck in between on and off
www.theapexinn.com
nah......I won't do it.
1 - 5 of 5 Posts
