1 - 3 of 3 Posts
I read several posts about blinker problems. My 05 Elise just developed this. Blinkers and hazards do not work on their own. Light work when I lock the car with the fob. Blinkers work when the hazard light switch is pressed. Fuses are fine. Bad hazard switch? Thanks!
Bad hazard switch?
You said you checked the fuses, did you mean fuses F6 and F9? There is a (small) chance it could be the flasher module itself but I'd guess the problem is the hazard flasher switch; they seem to be the most common problem for directional indicator and hazard light problems.
Bad hazard switch?
Yes, fuses were good. Seems plenty of people have had hazard switch issues that led to similar symptoms. Probably a good bet to just replace it I’m thinking.
1 - 3 of 3 Posts
