I've not seen a mention of a better timing belt option for those older car owners that have not found a $et of round tooth HTD pullies. At the risk of starting another boisterous belt discussion I offer the following.
Noting that some of the older parts cross refs mention early Nissan's used a 133 tooth trapazoidal belt, I looked into the models that used that belt and noted the 300ZX was one. Quick search for "300ZX racing timing belt" and I found that Gates offered one-
"-Constructed of HNBR elastomeric composites Up to 3x the lifetime of standard grade or OE belts
-Superior construction provides up to three times the heat resistance
-Gripping teeth reinforced with aramid and nylon rubber minimize wear
-As much as 300% stronger than the standard aftermarket belt"
These belts are slightly narrower than the Lotus specific ones, but the better materials should more than offset the width difference. Tooth engagement seems good, and I've run a Goodyear Gatorback "Nissan" belt before with no problems on the 910.
The Part number is T104RB, online prices are all over the place, I think I paid $65 USD.
As far as setting the tension or service life you're on yer own, I'm not going there....
