1 - 6 of 6 Posts
Slightly used, more like test fitted, is a BOE rear panel eliminator/delete panel.
I will update with pictures tomorrow as I ran out of daylight
https://www.boefab.com/products/diffuser-brace-and-panel-delete
I may not have the bolts for the license plate rivnuts that are on the panel but I believe they were 1/4-20’s. I can confirm that too when I update with pictures.
$160 plus shipping. Located in Chicago if you would like to pick up.
Discussion Starter · #2 ·
Bump with photo.
Found the hardware for the license plate holder.
Also have the bracket for the trunk/lid that is part of the BOE Clam Hinge. Basically what is pictured is what you would get from the clam hinge minus the hinges themselves. Which in reality you wouldn’t need if you don’t mind lifting the rear clam off entirely (just look at Radium’s kit).
1 - 6 of 6 Posts
