1 - 5 of 5 Posts
Hi all, I have installed my REV400 kit and BOE catch can but cant get the car to start.
The fuel pump, coolant pump and fans all start up however the car just turns over on the starter and doesnt catch?
I have checked the spark which is fine and I have fitted a new fuel pump assembly which I can here on start up.
Any ideas? Pretty frustrating :(
From my past experience with other Israel’s and issues afterwards, I would double check hoses in case any came loose during install. Good luck
I have started checking through etc but as my car is from the UK there are some changes to the instructions with regards to the charcoal cannister etc. I am hoping that these issues are causing the car not to start.
Right got a bit further and checked fuel flow through to the rail. The fuel pump is definitely working as it sent a jet of fuel out the line into a container. I am also definitely getting spark.
This makes me think its a sensor (crank or cam possibly?) or a problem with the ecu mapping....
The saga continues!
1 - 5 of 5 Posts
