1 - 20 of 39 Posts
2006 Lotus Exige Solar Yellow
No my parents did not pay for this nor did they fund my business ventures. I run a mildly successful online business and this has always been my dream car. Bought it from a Chevy dealer in Florida because the owner traded it on a C8. Currently working on getting rid of the carbon fiber wraps, the blued exhaust, and possibly the diffuser.
Roadtripped it all the way from Miami Beach to St. Louis then back to Columbia. Utterly miserable 馃槶
Currently in college in Columbia MO.
Tire Car Wheel Vehicle Plant
Wheel Tire Car Land vehicle Vehicle
Gauge Automotive tire Automotive design Plant Speedometer
07 Aspen White Exige S - MT
Congrats, hope you have another car for college as the exige is quite impractical for the college days.
Administrator
Welcome to LT Luke! Congratulations on your Exige ....at 18 no less! It's obvious you've been bitten! Just as impressive is the fact that you earned it! There's hope for today's youth!
Luke, welcome to the Lotus world. I also have an 06 Exige and I live close by in Blue Springs but I鈥檓 at the other end of the age spectrum, 73. Can鈥檛 imagine driving my Exige from Miami to Columbia. We鈥檒l done.
He's on fire!
I saw my first Elise in Columbia. Should be easy to find nice driving roads. I can't imagine the parking situation has improved, so it's great you have a second car. Definitely try an autocross.
Reactions: Luke D
Less is Better
As an owner of sports cars since I was 16, my advice is to get a little time in a driver's skills day or two. Porsche clubs do a really good event, you don't need to own a Porsche. It would have saved me from a few very scary incidents.
Discussion Starter · #12 ·
I saw a silver elise in a parking garage here at the beginning of college and then never again. 馃槩
Discussion Starter · #13 ·
Don鈥檛 think there鈥檚 many events in the fall and winter but I鈥檒l try to look.
Good work, at this rate you'll be selling stock in your enterprise some day. 馃憤
Nice car, and babe magnet (free bonus, lol). 馃槈馃槑
Reactions: Mai Mai
Discussion Starter · #15 ·
I have yet to see the babe magnet properties because everyones on thanksgiving break but I look forward to it 馃槷鈥嶐煉
Good for you.
1. These cars have large (i.e. dangerous) blind spots. Multivex mirrors are NLA, but RLS (Really Light Stuff) offers very good tape-on replacements/. GRP (Greg鈥檚 Racing Parrs) offers Extend -a-View mirrors, but I鈥檝e not seen them.
2. The horns are way too weak (quiet). There鈥檚 an inverse relationship: smaller the car, louder the horn needs to be.
Sounds like this 鈥渆xcuse me鈥濃.
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: 鈥淗ONK! LOOK OUT!鈥
Stop way behind trucks, SUVs, etc. Some have blindspots >50鈥. )
5. Transmission:
The best transmission lube I鈥檝e found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
a) Early cars have wobbly shift towers. Look up Stan鈥檚 Mod (bolt and spacer; http://www.billswebspace.com/ShifterReinforcement.pdf) and
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn鈥檛 get hot enough on street, leading to cam wiping.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE鈥檚 and InoKinetic鈥檚 for two examples.
8. While under the car with panel off, look around for hoses and wires chafing their way to failure. That鈥檚 how this was found:
11. Life will be better if you disable the auto-arming alarm function on the earlier cars. You won鈥檛 have to press a button to start the car. Instructions:
13, Some on this site are a bit obsessed with hockey pucks for lifting the car. Don鈥檛 use these. Too hard and slippery, generally, and too small a surface area. Use a piece of wood, as your hero does.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I鈥檝e helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, 鈥淗ow to bleed brakes鈥:
Maintenance and Repairs.
How to Search:
no space between site: lotustalk.com
1 - 20 of 39 Posts
