1 - 20 of 23 Posts
I just called Criswell parts (Gaithersburg Lotus Dealer) asking about the proper brake fluid to use when I do a flush on my 2005 Elise. I was told that any DOT 4 fluid was fine.
To get a more specific recommendation, I called Euroclassic parts (Richmond Lotus Dealer) and asked the same question. I was told that any DOT 3 fluid was fine.
:panic:
Could somebody tell me the correct answer, and perhaps recommend a brand that is commonly available?
Thanks
DOT 4 is a "better" fluid, in that it has higher boiling points than DOT 3. Nothing wrong with the Castrol LMA DOT 4 available in almost any auto parts store.
DOT 4
According to the 2005 Elise Owners Manual you should use DOT 4 brake fluid.
I used Valvoline SynPower brake fluid until they discontinued it.
Now I use Valvoline DOT 3 & 4 Brake Fluid.
Regards,
Wayne
Regards,
Wayne
I had been using the Valvoline, but recently they lowered the specs on boiling points, which was rather disappointing. Still nothing wrong with it.
Edit: that is, the new stuff is not as good as the Synpower.
Thanks. Very helpful.
So the same fluid can be both DOT3 and DOT4. That's interesting.
It's a "meet or exceed" sort of thing.
The only real difference between DOT 3 and DOT 4 brake fluid is the boiling point. All brake fluids must meet FMVSS116 minimum boiling points specification. DOT 4 is also less hygroscopic (less affinity for moisture).
FWIW, DOT 3 boiling point is 401 degrees F. DOT 4 is 446 degrees F.
Regards,
Wayne
I only use Castrol GTLMA (exceeds DOT 3 & 4 specs.), because of what LMA stands for "Low Moisture Activity"
+1
I've been using the stuff forever, and have never had a fluid related problem with and brake or clutch system. It lasts a lot longer than "regular" brake fluid in those cases where I don't get to flushing the system as often as I'd like to...
It is more complex than that, and the DOT 3 or 4 or 5 do not refer to the boiling point.
You can have different DOT3 with completely different boiling point, from 300 F to 660 F.
Do not touch DOT5, the pedal will be spongy, but it is better for the paint if you drop the oil to the paint.
Now, which one, DOT 3 or 4. No big deal, take any of both. It is more a question of chemistery about sealing.
If you are heating the oil by braking hard, go with some cheap DOT3 Ford at 550F. If you race or you are doing track day, DOT3 or 4 with a boiling of 600 is more than enough. And if you are very gentle with the car, just respect the car spec witj usual DOT4 oil spec, without taking care of the boiling point.
Many use ATE type 200 (amber colored) alternating with ATE Super Blue (Blue colored). It's basically the same stuff, just with different dyes. The change in color makes it easy to tell when you've flushed all the old fluid out. Both are DOT 4.
Having said that, Castrol LMA is a solid performer, and available just about anywhere.
Unfortunately LMA was only available in my area at Pep Boys, no others carried it.
Michael
· www.theapexinn.com
:up::up: Super Blue all the way !
here is an article from the stoptech homepage regarding brake fluid for those who want to learn more about it from a performance oriented standpoint.
it goes into the differences between dot standard and racing fluid as well as the advantages and weaknesses of different types of fluid.
RBF600 here too...
It has always worked for me. If you track the car, I recommend it. If you don't, any dot4 would work for you for street/auto-x.
Taken from the article
As a trailing note on the DOT ratings, if your car was designed for a particular type of fluid (especially prior to the development of DOT 4 fluids), you should make every attempt to stick with that fluid! For example, if your car was delivered with DOT 3 fluid, the internal components of the system (seals, brake hoses, and fittings for example) were specifically designed and tested for compatibility with DOT 3. Because DOT 4 fluids contain a different chemical composition, the system may not necessarily react in a positive fashion to the borate esters floating around in the mix.
1 - 20 of 23 Posts
