1 - 3 of 3 Posts
I have a 2005 Elise that recently developed a brake fluid leak due to deteriorated brake lines. I had all of the brake lines replaced by a very reputable Lotus mechanic and other than the brakes feeling a little soft at first, the brakes felt fine.
I drove the car about 5-6 times for a total of about 70-80 miles over the 4-5 weeks since I had the work done. I went to drive the car yesterday and brake pedal had zero resistance. I checked the brake fluid reservoir and is it empty. Dry as bone. The odd thing is that I can't find a drop of brake fluid leaking anywhere. Any thoughts? I am planning on taking the car back to the shop that did the work but trying to get some input...
Administrator
May have leaked past one of the replaced lines. In any case unsafe to drive before returning to dealer.
I have no idea...but since the clutch fluid is shared with the brake reservoir...could you be losing fluid there? You wouldn't really see a leak until you drop the under panel. It's located in a tough spot.
1 - 3 of 3 Posts
