1 - 3 of 3 Posts
I was at a track event at Sebring on 6-21-09. I was experiencing a wierd brake problem. After the threshold braking on turn 7 when I would get to turn 10 the pedal would catch at about half way down of the normal travel and would only brake at about half force. This would only happen for about a second then the pedal would go down to the nomal position and brake normally. This scenerio would only seem to happen at turn 10. I have fairly new Pagid blues with Motul fluid and SS lines. I did a bleed at the track but it did not help. Anyone have a problem like this??::shrug:
www.theapexinn.com
search: Ice Mode
wiggle your rear pads to make sure inboard and outboard pads are against the rotor with no play (ebrake disengaged). If there is play then do a search on my post about my brakes. Crank the ebrake up firmly to adjust rear pads.
If this doesn't solve then your car may have caught the Ice mode flu
There could be several other reasons this might be happening. I am only offering what I found with similar symptoms.
1 - 3 of 3 Posts
