I have a brake issue which I am working to improve by changing again the brake pad (actual Pagid RS4-2, changing for something better, I don't know yet), changing the weight of the disc (actual: stock, changing for 295-28 Alcon), and of course add new brake hose (actual: stock, changing for stainless type). I am using already Motul DOT4 600 brake oil, and I am changing it like every lapping day. I am not smouth with my brake. I am using my Elise on street and lapping day, but driving at race speed during lapping.
But, it still for me a big question about one very strange thing happening on my car, and maybe the cause can be somethinbg else, including the ABS.
During lapping, the pedal start to be more and more spongy, caused probably by heat, and fade of the pad. The worst case of the spongy pedal is all time when I am returning to the track after a car cool down, and the cool down time can be as high as 45 minutes, no matter. Typically I need to pump the brake to be back with a working pedal, go to the track, after first corner, I restart pumping the brake and after I am ok to start with a better pedal.
At the beginning, I was thinking that I did not let enough cool down before to return to the pit. My feeling was maybe the heat is going to the caliper oil when the car is stopped. Saturday, I was doing a 2 lap cool down to see if the cool down should be the cause. No changes, the pedal was spongy a lot.
I don't understand the cause. I raced many years without that kind of trouble on my other car, not equipped with ABS. My brother saw the same king of pedal issue with a Austin Martin DB7, equipped with an ABS.
Is it possible that for any reason, the ABS is doing something on the brake circuit. At the moment, I have tendency to think about a hydraulic issue more than the heating issue to explain a spongy pedal after a long cool down.
So, anybody else with this trouble?
If the ABS is the cause, I will remove it.
Any input will be appreciated.
