1 - 4 of 4 Posts
Ok - I've own my Elise for around 2 years now and haven't had any issues with it aside from a bum turn signal. Over the past week I've been hearing this noise while braking, after accelerating up to a RPM over 4K and letting off the gas, or simply cruising on the freeway. The noise isn't exactly a gurgle, but kinda sounds like Darth Vader when he exhales or inhales. I thought it had something to do with A/C, but turning it off and driving around didn't change anything. Perhaps it has something to do with the brake fluid and air in the lines? Sadly, I can't recall what my brake pedal has sounded like over the years and once I started hearing this Darth Vader sound I notice that when I press the brake pedal down I hear a hydraulic/pneumatic type sound.
Thoughts are appreciated :)
Thanks,
:DV:
German Reimport
Well, it is obvious that Darth isn't in your passenger seat since you would have noticed him there.
Did you check in the trunk?
Well he could be playing a mind trick on me and is indeed in the passenger seat.
I think I might have the SHHH problem someone on here posted about.
Now that the sound is a little more prominent it is clearly worn pads. Move along here, nothing to see here :)
1 - 4 of 4 Posts
