I suspect I’ve got a boost problem but have gone through almost every system without any smoking gun.
Does anyone have a boost gauge connected to their SC Elise, and can you tell me what the max boost you’re seeing in the heat of the summer? Has the boost changed/do you see it change with outside temp?
-I’m seeing about 5psi but had seen 7psi with a different gauge during the winter.
Has anyone logged MAF readings at wide open throttle and what were the readings?
Have you been to Bandimere and what times did you run and what were your trap speeds?
-I was running a consistent 14.6 in the mid 90 mph
Would anyone be interested in doing any dyno runs if I decide to re-dyno my car. Does anyone have a shop they would recommend in a 40 mile radius of Boulder? (the Super Rupair guy is moving his shop right now)
