1 - 2 of 2 Posts
I will be running a brake rotor with a thinner hat face than stock. I will need to space my Volks CE28n wheels back out a bit to maintain wheel-to-caliper clearance. With the thinner rotor hat face it is possible that the center bore of the spacers would not fit perfectly due to the fact that the hub spindle diameter flares out as it approaches the hub face.
So here are my BWR spacers freshly chamfered 1/16th deep on the ID.
The quick answer is no since the rotor face is still thicker than the radius at the base of the hub but it's a moot point anyways since you got a 1/16 chamfer ..... Isn't it????
1 - 2 of 2 Posts
