1 - 4 of 4 Posts
Guys,
Does anyone know the size of the bolt used when relocating the alternator into its new position? This is the gen 2 BWR install.
Thanks,
Rhali
If i am not mistaken the alternator has threads and the same stock bolt is used through the nose bracket. I will check size and get back.
M8 bolt not sure of length but must be long enogh to go through s/c nose bracket and into threaded portion of alternator. You should also put a nut on the end as well. Email Fred he will know.
Thanks Tommyc, thats exactly what I was looking for. The bolt sheared off and vibration cause the lower alternator bolt to walk off. Im amazed the entire belt didn't slide off on me.
any thoughts on the size of A120F7169S ? its the lower bolt that holds the Alternator into place.
Thanks,
1 - 4 of 4 Posts
