1 - 6 of 6 Posts
Trying to find a factory service manual for the C64 trans. Pulling it apart to put in new gears and limited slip and it would be helpful as I've never been in a Toyota manual trans.
Found once for the C60 trans, is that pretty much the same other than different ratios?
C64 = C60 w/ different 6th gear. the C64 case is even stamped C60. use the FSM you have, it'll be fine. but BE SURE you get the preload right for the diff - FSM specs assume open diff, which will be instant death for your gearbox if you're installing TRD/OSG/etc
link for C60 ?
close enough for me
1 - 6 of 6 Posts
