1 - 9 of 9 Posts
I have a 2006 Elise. Heat/A/C 3 position switch went. I think likely the dreaded resistor pack but wanted to check the C1 fuse (I believe that is the right one). Easy to find but I noticed the C2, C3, and C4 fuse slots are empty??? My radio and wiper motor both work fine, which is what I thought they were for. Am I looking at an old fuse diagram? Would they be somewhere else now?
BTW - C1 looked fine so I think even more likely the resistor pack, unless anyone else has suggestions.
At least on my car (which has some sketchy wiring from previous owners), there are two cabin blocks despite only one on the wiring diagram. Maybe a second one was hiding in plain sight?
yea, I had two blocks of 4 slots each. One block only had 1 fuse. The other had all 4 fuses in there. They were right next to each other.
Discussion Starter · #7 ·
I'll check in a bit. Sounds like the 1 fuse block may have been holding a spare. (?).
C5 is actually for the driving lamps if you have them. if not then yeah its a spare.
Ah, that makes sense. I have the wiring for driving lamps (figured everyone did) but no lamps themselves. Always assumed it was just to keep one harness design, but now I think a previous owner ditched them
1 - 9 of 9 Posts
