If you look inside any transmission, side to side movement, so to speak, is ONLY possible when the shift selector is at or very close to a center fore-aft location. However, since a cable transmission usually has more "slop" than transmissions with the shifter built into the transmission, they also require slightly more exaggerated movements to account for slack in the cables and what-not.
Also, the lotus shifter also has very little compliance. A vehicle with a linkage type transmission (i.e. an older civic) will have rubber bushings that effectively preload the left to right action of the shifter, allowing the shifter to feel like it's moving to the right, when in actuality, you're loading a rubber spring, which releases it's energy once you enter the neutral area of the gearbox. The result of this is the sensation that you're actually moving the shifter diagonally, but right at the transmission, the gear selector is moving down then right, then down.
Does that make sense?
