1 - 14 of 14 Posts
Hi all, I just pulled my valve cover to check my cams. Build date is August 05, 10,000 miles. Cyl 3 and 4 are perfect 1 and 2 have some discoloration but when I rub my fingernail across high part of lobe it is smooth. No other problems with car. here are pictures from cyl 1-4 what do you guys think? worry or not? Thanks in advance. Tommy
Discussion Starter · #2 ·
ok a little large not sure how to reduce size. and other picture it is telling me are too large file size wize any ideas?
if you dont have ANY software tha can resize photos, you can create a photobucket account that will host your photos and allow you to resize them. Or you can download a simple image resizing utility... like "Image Resizer" from microsoft power toys...
Microsoft PowerToys for Windows XP
Thats assuming you have a PC... if you are using a mac... there is no help for you :)
ok les try this again. number 1
number 2
Discussion Starter · #7 ·
no 3
Discussion Starter · #8 ·
no 4
Discussion Starter · #9 ·
Thanks zygotesoup that worked good! any respone? maybe Monday.
I know little about this cam lobe issue... but to me they don't look too bad. There is some discoloration in #1, but there doesn't sem to be any significant wear. What exactly is the discoloration from?
Discussion Starter · #12 ·
actually here is the picture of no 1 without the flash I think there ok
Discussion Starter · #13 ·
maybe they need to used more!!!!!
Discussion Starter · #14 ·
Hi all just thought I would post up the toyota part numbers for the gakets needed to remove and replace the valve cover. You can probably get away with using the same ones but I always replace any O rings.
Cylinder head cover gasket: 11213-88600
ventilation pipe gasket: 12255-88600
O ring:96741-19009
The whole job takes about an hour working slowly. I did mine at oil change time. Good peace of mind being I would love to go forced induction as soon as the warrenty is up.
Hope this helps.
1 - 14 of 14 Posts
