1 - 3 of 3 Posts
I own a 2004 Lotus Elise S2 111S with the 1.8 K series engine.
The car hasn't done may miles, approx 15K and has been serviced annually by the local Lotus Dealer in Newcastle Upon Tyne.
Unfortunately this dealer s no longer trading, and the car has now developed a issue....
While out on a run the car seemed to make a pop (or maybe a backfire) after which it started to misfire, and the engine light came on....Limping back home I have been able to attach a ODBC reader and download the fault codes
P1302 : Boost Calibration Low
P1301 : Boost calibration High
P0300 : Random/multiple cylinders misfire detected
P0340 :- Camshaft position CMP Sensor A bank1 – circuit malfunction
Thinking P0340 would solve the problem, I removed the CMP and checked the part as being NSC000010.
Unfortunately I was unable to find anyone who stocked this part, however was offered a aftermarket replacement part, P/N NSC000010P.
The part arrived and was fitted, however this has not solved the problem, the car tries to start but doesn’t
I would therefore appreciate and suggestions on where I can next look / check
Thank you
Stephen
Administrator
Stephen you might want to post in SELOC as LT is primarily US Fed Lotus cars.
1 - 3 of 3 Posts
