1 - 9 of 9 Posts
I assumed that I had a factory muffler until I heard an unmodified Elise. Now I'm thinking about going back to factory to avoid trouble with the Gestapo. Can somebody ID this muffler?
Is there not some number or other distinguishing mark somewhere on the body?
It turns out that there is a tag on it:
CLF Muffler
Numbers
For Track Use Only
More Numbers
From a quick search. It sounds like this muffler isn't well built, but I don't see anything visually wrong with the welds at this point.
Could be a stage two that has been run hard and had all of the packing wear away. That would definitely equate to louder than a normal version.
Omg my Janspeed built stage 2 drones like crazy after 2 track days without a cat. It is so loud. But it sounds AWESOME! I have to use ear plugs in my car, so unfortunately it has to go :(
When people talk about broken welds, where do they typically break? I had some nasty resonance recently at 3000 rpm. I pulled the muffler and saw that both support brackets welded from the muffler can to the exhaust tips had fatigued in the heat affected zone just beyond the weld. I welded them back together and it has held fine, but it's only been a week. If it goes again I'll weld it again, but it really is too loud to ride in the car, so maybe I should research other through-diffuser mufflers...
Vroom vroom
Some of the CLFs were good, some were done poorly. You can tell by checking those numbers, though you'll have to research that yourself as I don't recall which ones were good. It came down to one dude who wasn't very good at his job.
Discussion Starter · #8 ·
I took a photo through a mirror and was able to decipher most of the numbers:
CLF
MFFLER
121S0002
L0030008
L02/52118/19/05
I actually like the sound of it. At freeway speed I pretty much have to yell to have a conversation, which is the downside. I can't see how it could possibly make sound at Laguna Seca. One of my first track events was at Laguna Seca in 1999 and I was passing everything going up the hill in my mostly-factory 86 Mustang. I was talking to an F355 F1 owner about it and he laughed and asked if I was lifting. I said of course not. He then told me that the sound meter is on that hill and all of the cars I passed have to lift to make sound. Oh!
1 - 9 of 9 Posts
