1 - 10 of 10 Posts
of using the Lotus rear brace chassis kit? Thanks.
I believe it is used to reinforce the rear toe link, which has been known to snap under heavy track use.
· insert clever title here
The stress on the toe links will increase if you're using stickier track-oriented tires (A048 or even slicks). I'm not sure that a user on AD07 street tires would really benefit from the brace, but if you're using stickier tires and pushing the car hard on a track, it'd probably be a good idea.
There's a European(?) supplied kit that involves putting plates (attached to the chassis) over the inboard mounts to put the bolts in double shear.
There's a guy here who replaced his toe links with shorter links which attached to welded-on flanges on the lower A-arm.
Sector 111 supplies a couple different kits which are lower cost.
I thought the track pack addressed this. I don't understand why they would include these sticky tires with an exige if they knew it would cause issues...:huh:
Oh well. I guess I'll cross that bridge when I get there.
The track pack toe link brace is in double shear (which reduces shear stress on the bolt), but transfers some stress to the opposite side bolt/link (reducing some effectiveness of the "double" shear)... some aftermarket braces have a plate that attaches to the engine/transmission mount, effectively making the chassis take the stress more directly.
1 - 10 of 10 Posts
