I'm trying to enlarge the holes a carbon fiber splitter. Can I just drill or dremel it or am I going to create a problem for myself? Never messed around with carbon fiber before.
I'd use the higher speed dremel tool to enlarge holes. Carbon fiber is very strong and not nearly as fragile as fiberglass. Sharp drills and high speed will work much better.
What ace 10 said... You don't want to inhale any of that CF dust, the body can't break it down. Goggles, while inconvenient, are a lot better than having a piece of shrapnel dug out of your eye by an ophthalmologist.
Don't get too paranoid about it, I have cut alot of CF and Carbon/ Kevlar - I kinda like the smell of it actually, Carbon cuts and sands very easily with most high speed bits or sanding drums from Dremel - Be cautious if you use a Rotozip spiral bit as they tend to "Crawl". Treat your project as if you were cutting fiberglass.
For this application, I think you're probably OK. If it were a more structural application, I'd advise against drilling into CF.
Once you do enlarge your holes, the paranoid part in me would reseal the area you drilled using epoxy, just to reduce the chances of delamination/water absorption.
