1 - 5 of 5 Posts
purveyor of lightness
I've searched and Googled and can't find the following things:
- Connecting rod length (mm) / Rod ratio 1.5? 1.6?...
- Deck height (mm)
- Inch/lbs pressure for stock intake/exhaust valve springs
- Stock piston dish/dome cc's
I'm going to do the math for stock 11.5:1 compression then see what would be involved for:
a) Stroker kit
b) Lowering compression to a more reasonable 9.3:1, possibly posting the block and supercharging the thing. I like turbos but HELL no on an auto-x course. N i c e... l i n e a r... p o w e r... mmmm
Anyway, if anyone has that info then please post here.
Thanks!
Hi DarkSol,
Are u product of dark matter?
If you make things faster I will sell part of my soul to you but only a small part cuz I owe others.
Are you going to let your sis drive your car?
Sorry I dont have tech info for you but there is a thread linking white papers on the motor but I dont know if there is enuff info.
Also try installing copernic search agent (free) from tucows.com very useful tool like a wet hammer.
Olive skinned Sol
Trial (iirc) makes a stroker kit. It is basically a stock 1zz crank, custom rods, and pistons. A crank spacer and rear main seal.
Sorry I did not document the rod length when my engine was down. I would pick up a spare 2zz from e-bay. One can be had for about 800.00-1100.00.
A super charger would be great but it is going to be a tight fit.
1 - 5 of 5 Posts
