Main fuse box
Slot Rate Circuit
1 20A Aux pwr socket
2 5A Reverse lamps
3 20A Driver’s window
4 20A Pass. window
5 10A Stoplamps
6 7.5A Turn indicators
7 10A Ignition services
8 7.5A Battery services
9 15A Hazard lamps
10 7.5A Horn
11 10A Alarm pwr, interior lamp
12 10A ABS
13 3A ECU Ignition
14 20A Rad. fans; 1&2 slow, 1 fast
15 7.5A Radio, switch pack module
16 10A Parking lamps
17 10A Dip beam LH
18 10A Dip beam RH
19 20A A.C. comp. relay, rad fan 2 fast
20 15A Main beam LH
21 15A Main beam RH
22 7.5A CDL
Engine Compartment Fuses
Fuse Rating Circuit
R1 20A Fuel pump
R2 3A Immobiliser
R3 5A Alternator sense
R4 5A ECU battery feed
R5 5A O2 heaters
R6 7.5A VSV's VVT, VVL, IAC
R7 10A Injectors, ignition coils
R8 5A Re-circ. pump
Footwell Fuses
Fuse Rating Circuit
C1 20A Interior fan
C2 15A Wiper motor
C3 7.5A Audio key-in
C4 7.5A A.C. compressor
this is all I have, from owner's manual
edit: Can't imagine moved from eng compartment. Get a good light.
Slot Rate Circuit
2 5A Reverse lamps
4 20A Pass. window
5 10A Stoplamps
9 15A Hazard lamps
10 7.5A Horn
12 10A ABS
13 3A ECU Ignition
17 10A Dip beam LH
18 10A Dip beam RH
20 15A Main beam LH
21 15A Main beam RH
22 7.5A CDL
Fuse Rating Circuit
R1 20A Fuel pump
R2 3A Immobiliser
R5 5A O2 heaters
R8 5A Re-circ. pump
Footwell Fuses
Fuse Rating Circuit
C1 20A Interior fan
C2 15A Wiper motor
