Been having intermittent problems with the fobs losing sync with the alarm, and getting progressively worse. But at this point, I simply cannot get either fob to get back in sync with the alarm.
I've tried the re-sync procedure dozens of times now. After entering the PIN on the alarm and getting the red light to stay on, and pressing both buttons on the fob until they stop blinking then turn to a steady light, pressing the big button does nothing except make the fob light blink. The light on the tach never goes blinks or goes out as a result of getting the signal from the fob. I've already replaced both batteries on the fobs and even bought a new battery for the car (optima red top 75-25). I've made sure the dome light is in the down position. I've also unplugged the wire harness from the alarm and re-connected it.
I've never had this problem before - I've been able to sync several times in the past, but the alarm now will simply not communicate with the fob - as if it's not receiving the signal from the fobs. And I've tried with both fobs.
I'm going to do the immobilizer bypass tomorrow because I'm forced to have to put the pin in every time I need to start the car, which is a real PITA. Aside from that, I can only lock/unlock the car with the key.
Any ideas? This is unbearable.
