1 - 19 of 19 Posts
Forgive me if this is already posted.....
Discussion Starter · #2 ·
2
3
4
5
cool...thanks
Discussion Starter · #7 ·
6
shay2nak
doesn't this exige have black LSS rims on it? check out the profile of the car at speed. you can clearly see the discs, to me suggests very little surface area from the center to the lip. Much like the LSS rims.
it reads "black cast alloys can be replaced by even lighter forged wheels."
They are black, but the Exige has a different wheel design as standard, most likely made by the same manufacturer. You can get the sport pack wheels if you want.
after you try to cleaning them for the first time you won't, unless you like cleaning both sides of the 16 spokes per wheel. multiplied by 4 wheels, that's 64 spokes you'll have to get in and out of to clean. i'd like a set of thos kms 5 spokes or ssr comps, now those are really nice and easy to clean.
I fired my friend up Mr. Photoshop, and combined the two halves at full rez. I had to chop the right half of the image up into 3 seperate sections because the scan wasn't completely flat so the page didn't actually match up with the left hand side. Then I took and removed the color variation down the midle because the right hand side also came out lighter then the left. Then I touched up the scan streaks down the left and right hand sides.
Enjoy.
-Leith
1 - 19 of 19 Posts
