1 - 18 of 18 Posts
Hi folks! I’ve been working overseas for a few years and my wife has been working in the US. She’s finally getting settled in Cleveland and I’m getting the itch to repopulate the toy collection. Previously had a ‘68 Triumph Spitfire and a tuned ‘11 BMW 135i. Still have a couple of Miatas for racing, but not road-legal.
While I’d started shopping for a Caterham Seven, I’m now moving towards an Exige (preferably) or an Elise as something slightly more wife-friendly.
I’ll look forward to reading more about each car here as I continue my search!
Cheers,
Bryan
Supporting Vendor
Bryan,
Have a look at our Black Shadow Motors website. We have been buying nice clean titled Lotus that we are refurbishing and making as mechanically nice as possible. Based on the request of the Buyers, we have also been upgrading many of these cars with some of our tasty bits. I am expecting a nice Exige S to come my way later this month or in Sept.
Feel free to call me to discuss - though this week I will be in Monterey Car week.
Sold (to me)!
It took a couple of months and some patience on both my part and that of sellers dealing with me while overseas...
But, it's finally happening and there's an Isotope Green 2008 Exige S240 on it's way to a new home in Cleveland!
Still excited to be joining the club!
Cheers,
Bryan
Cheers,
Bryan
Hey Bryan I'm in the Cleveland area, just outside Strongsville. Any chance we could meet up sometime when you get the car and let me sit in it? I am looking to buy one come spring but I have yet to sit in one lol.
Sent from my SM-G960U using Tapatalk
Congratulations!!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Discussion Starter · #7 ·
Don't let that stop you! I've still never sat in one... hopefully tomorrow when it's delivered.
Send me a PM later and we can see if there's a time to meet up over the winter.
Cheers,
Bryan
Congrats on the purchase. Beautiful and rare color you got there. Share more pics once she comes home to you. Enjoy!
Discussion Starter · #10 ·
It sounds like delivery will happen just AFTER leaving for another overseas work stint, so I'll see it at Xmas for the first time. I'll share whatever photos my wife shares with me!
Now I can spent my travel time researching upgrades!
Cheers,
B
Cheers,
B
Since I'm nearby.... and you're gone.... I could oversee the delivery for you, and take it on a few hundred mile test drive to make sure everything is good lol.
P.S. the color is amazing, I love it.
P.P.S. when you come back and there's a GTI in your driveway and not a Lotus.... don't be alarmed. Still test driving
** The Enforcer **
Nigel is finally in his permanent home...
I've never heard of a car using a male name. I found this portion of the link I've included as interesting.
Female Pronouns for Objects
Both hardcover (1) and online dictionaries agree: The pronoun “she” can refer to inanimate objects. The entries for the pronoun “he,” on the other hand, do not mention anything about personification. So, it is common to hear a ship or a car referred to as “she” but not as “he.”
San
1 - 18 of 18 Posts
